Old 10-17-2008, 10:26 AM   #1 (permalink)
mislatero is on a distinguished road
Default Are there themes for WM6 with appearance of w6.1?
Hi!
thanks!
mislatero is offline
Old 10-17-2008, 10:34 AM   #2 (permalink)
sliding panels ?
docmac made a very nice "clone".. http://www.everythingq.com/forum/q-h...one-27017.html
Old 10-17-2008, 11:51 AM   #3 (permalink)
sliding panels ?
thanks but I could not run fizz travel. http://www.fizzsoftware.com/products...traveller.html
on the Docman themes
Are there other themes?
Old 10-17-2008, 11:55 AM   #4 (permalink)
he doesnt use fizz traveler
in that link rb provided one of the plugins is fizz weather
Old 10-17-2008, 12:25 PM   #5 (permalink)
docmac129's Avatar
Fizz Weather could be removed with little effort if u just ask. It would take about 10 minutes.
docmac129 is offline
Old 10-17-2008, 01:12 PM   #6 (permalink)
I already have time fizz pluggin but I have another problem
I can not see the date on the bottom
Old 10-17-2008, 01:40 PM   #7 (permalink)
docmac129's Avatar
Go to Start>Settings>Regional Settings>Long Date Style> & Choose October 17th, 2008 (Second Choice down) & the screen will fit like it is supposed to. If u want the day in there like Friday blah, blah blah then the xml will have to be edited to accomodate that.
And do u have facade?? I don't see your schedule below. U would need Facade for that screen. If u don't, the xml would have to be changed to the normal calendar plugin.
Old 10-17-2008, 02:05 PM   #8 (permalink)
thank you.
1I installed facade 1.31
2.it will try to do what you say.
3 nice theme congratulations
Old 10-17-2008, 02:08 PM   #9 (permalink)
thank you.
i think you are going to need to update your facade to version 1.4.9
Old 10-17-2008, 02:23 PM   #10 (permalink)
thanks
my problem was the calendar it was only that i didnt have appointments
