Well, I've reworked the image a bit, and come up with two different designs.
"Image 1"
"Image 2"
I'm leaning a bit towards "Image 2", as it lends itself to a cleaner version.
Matt, which one do you perfer, and do you have an idea on your choice of text color and soft key color?
Of course, you can choose both, as the layout I'm thinking of will work on either. You'll just have to keep the images in seperate folders and rename, and reload to your Q when you get the urge.
