Old 09-27-2007, 10:16 AM   #11 (permalink)
And here's what the final finished product looks like. I had a tough time squeezing everything on there, and if I could have reduced the image, I could have squished more on. I felt that the size of the truck in relation to the screen was important.
"Right Click" and "Save As"
I like the look of "Image 2" when its built into the screen. I have included both images in the zip file.
Enjoy.
Der Alta is offline
mlbecknell (09-27-2007)
Old 09-27-2007, 10:18 AM   #12 (permalink)
how patriotic!!
nice job
Old 09-27-2007, 10:59 AM   #13 (permalink)
mlbecknell's Avatar
mlbecknell is on a distinguished road
Send a message via Yahoo to mlbecknell
i'm thinking number two all the way. letters white or yellow soft keys red maybe if posible
matt becknell
mlbecknell is offline
Old 09-27-2007, 11:20 AM   #14 (permalink)
I'll experiment with the Yellow text a bit and see how it looks.
Glad you liked it.
Der Alta is offline
Old 09-27-2007, 01:29 PM   #15 (permalink)
mlbecknell's Avatar
Smile
Der Alta: thanks for your help brother you can still try to play with the yellow letters. but i'm using the white ones right now so they show up really good on the home screen you made me.
matt becknell
Old 09-27-2007, 02:19 PM   #16 (permalink)
Consider it revised. I also tweaked the layout very slightly.
Psst... Hit the thanks button ;)
Der Alta is offline
Old 09-27-2007, 03:13 PM   #17 (permalink)
i like the other colors better.... but never the less a great hs again.
Old 09-27-2007, 04:28 PM   #18 (permalink)
SingBar's Avatar
SingBar is on a distinguished road
Send a message via AIM to SingBar
I guess no one like mine..... haha
SingBar
SingBar is offline
Old 09-27-2007, 04:47 PM   #19 (permalink)
yours was alright, it just looked like a mad dinosaurs stomped on the fire truck :]
Old 09-27-2007, 04:49 PM   #20 (permalink)
SingBar's Avatar
What can I say.... I'm prehistoric :}
from the Q
SingBar is offline
