Old 06-12-2008, 09:05 AM   #1 (permalink)
Default a solid...
who can do me a solid ? and make a background in what ever it is you use for images ?
Old 06-12-2008, 09:07 AM   #2 (permalink)
docmac129's Avatar
What exactly r u looking for RB? Give us some details & we'll throw some your way!
docmac129 is online now
Old 06-12-2008, 09:28 AM   #3 (permalink)
well.... i want this image: http://mq.roeiboot.com/backgrounds/circuits.jpg
(thanks to rbrainard) and the "close to transparent" box(es) on it like this screen: http://mq.roeiboot.com/public/various/wm61.jpg... the other little icons and what not i can mess with... i want the bigger "box" not quite that high so i have room underneath for appointments and maybe the sms/mms/email indicators.
not sure i what you make it... i have Paint.NET, and also but not yet installed PhotoShop.. if possible i want it in layers so i can mess with it if need be..
thanks...
(yes i possibly have some wm6.1 home screen envy :}
Old 06-12-2008, 09:29 AM   #4 (permalink)
crazykay's Avatar
crazykay is on a distinguished road
Send a message via Yahoo to crazykay
I imagine he wants something to do with that little man in the hat!!???
crazykay is online now
Old 06-12-2008, 09:30 AM   #5 (permalink)
crazykay's Avatar
dangit rb you beat me to it again!! ok so I was wrong!
Old 06-12-2008, 09:32 AM   #6 (permalink)
a close relative of that "little man" has been on my screen for quite a while now... i think i am ready for a sans skaman screen :}
Old 06-12-2008, 09:39 AM   #7 (permalink)
Desktop software
you have no idea how often i hear these very words :}
Old 06-12-2008, 10:14 AM   #8 (permalink)
crazykay's Avatar
lol well ya know with as many posts as you have I should know better!.. this sounds like a project for docmac,eko or der alta! I could make the image for you but im no good at the animated hs's and that sounds like wat you want.. good luck
Old 06-12-2008, 10:27 AM   #9 (permalink)
well... i meant overall, in life :}
not animated... just simple screen (most difficult will be the layers ?)
Old 06-12-2008, 11:15 AM   #10 (permalink)
docmac129's Avatar
I know CrazyKay or I can do it for u, but we both use Photoshop. We could make it and send u the .psd file so u could alter it with any icons or such, & that way u can manipulate the layers also.. Go ahead & take the leap, install photoshop. U won't be disappointed!!!
The Following User Says Thank You to docmac129 For This Useful Post:
rudeboy (06-12-2008)
