Go Back   Motorola Q Forum | Everything Q > Other > Product Announcements
Old 06-18-2008, 09:40 PM   #51 (permalink)
TreeFrog's Avatar
Originally Posted by mworsham View Post
New Text Message Received
ok..haha..had to ask!
...I for now have nothing!
TreeFrog is online now
Old 06-18-2008, 09:40 PM   #52 (permalink)
QoreFunctions is on a distinguished road
Lightbulb from QoreFunctions
Try reinstalling ET to main memory then install PopUps again. Then restart your device. See if that helps it detect the alternate SMS reader. This has been extensively tested on WM5 and 6 devices, so we know it works. Another poster has also confirmed it successfully detected ET on their device. Your registry may be corrupt.
Nifty little apps that make life a little easier!
Download free trials at
www.qorefunctions.com
QoreFunctions is offline
Old 06-18-2008, 09:44 PM   #53 (permalink)
dafoxs's Avatar
would ther be a way to kill the popups if you are reading a text message? that was annoying.theres got to be a way.
dafoxs is online now
Old 06-18-2008, 09:46 PM   #54 (permalink)
Unfortunately not with this version, maybe in the future. You could simply hit Dismiss though, that's what its there for!
Old 06-18-2008, 09:54 PM   #55 (permalink)
mworsham is on a distinguished road
Send a message via Yahoo to mworsham Send a message via Skype™ to mworsham
Removed both programs and reinstalled both to the card. No options.
Mark W
mworsham is online now
Old 06-18-2008, 09:57 PM   #56 (permalink)
Mark W
Try reinstalling to main memory.
Old 06-18-2008, 10:03 PM   #57 (permalink)
I hear ya! Which Q do you have? I am using the Q9h, can't imagine why that would make a difference.
Old 06-18-2008, 10:24 PM   #58 (permalink)
dafoxs's Avatar
on page 3 there is an animated gif. do your screens look like that? it works fine on my Q9C and I have 6.1 also.Have you ever changed font colors?
Old 06-18-2008, 11:12 PM   #59 (permalink)
TreeFrog's Avatar
@ mworsham...Im original Q..wm5.
@ Qore...did you have a 9h tester?
Old 06-18-2008, 11:16 PM   #60 (permalink)
TreeFrog's Avatar
@ dafoxs...I thought of that too but he can see the first checkbox and verbage so the second line should show also! Weird....
