Go Back   Motorola Q Forum | Everything Q > Other > Product Announcements
Old 06-18-2008, 04:31 PM   #31 (permalink)
Tony Bag o Donuts's Avatar
Originally Posted by dafoxs View Post
are we both lokking at the same program? I only have dismiss and reply for buttons..no Message button.
same here.
scrolling also goes to the next message instead of scrolling through the entire message.
also I am getting a noticeable delay between when I get the notification sound and when this app starts up. It is installed to my card.
My photography website.
leave comments, etc.
Tony Bag o Donuts is offline
Old 06-18-2008, 04:39 PM   #32 (permalink)
TreeFrog's Avatar
hmmm..maybe because I use their PushEffect program? Not sure now! You can see in my screenshots I have a message button. Are you talking sms and not email?
TreeFrog is online now
Old 06-18-2008, 04:44 PM   #33 (permalink)
dafoxs's Avatar
You are right, the message button comes up on email only. WARNING..don't hit the phones message button, read the text and delete it. the pop up won't go away. it keeps flashing. guess you have to "Dismiss" the pop up before deleting the message. had to reboot the phone to get rid of the popup
dafoxs is offline
Old 06-18-2008, 04:58 PM   #34 (permalink)
TreeFrog's Avatar
yup..message button for email..reply button for sms unless you check the alternate sms reader option!
And I haven't tried hitting the phones dedicated button. The soft key messaging button takes you straight to that email!
Old 06-18-2008, 05:00 PM   #35 (permalink)
mworsham is on a distinguished road
Send a message via Yahoo to mworsham Send a message via Skype™ to mworsham
Do you have eXtreme Text installed on your phone or on a card? Mine is on the card, and I wonder if this program is not seeing it and giving me the alternate SMS check box because XT is on the card.
Mark W
mworsham is offline
Old 06-18-2008, 05:00 PM   #36 (permalink)
dafoxs's Avatar
so if you want to read the entire SMS, you have to do it the old fashion way. i'll disable that and use the sliididng panel.
dafoxs is offline
Old 06-18-2008, 05:12 PM   #37 (permalink)
TreeFrog's Avatar
Mark W
Yes...my ET is on the card. You don't have the same check box in settings? Qore does of course recommend installing this on the device! I always try both places..if it acts weird on the card to the device it goes. I currently have both popups and et on the card.
sliididng panel sounds interesting!
Old 06-18-2008, 05:14 PM   #38 (permalink)
Weird, I have both on the card, but I am not getting any of the "extra" check boxes.
Mark W
mworsham is offline
Old 06-18-2008, 05:19 PM   #39 (permalink)
TreeFrog's Avatar
Mark W
try unchecking "system shortcut to XT" in extreme text...and reboot. I've never had that checked so maybe that is the difference!
Old 06-18-2008, 05:22 PM   #40 (permalink)
I don't have that checked. I didn't like the way XT "took over" my Outlook e-mail when I had that option checked. I did just reboot to see if it made any difference; no go. Thanks for the ideas!
Mark W
mworsham is offline
