Go Back   Motorola Q Forum | Everything Q > Other > Product Announcements
Old 07-25-2008, 03:32 PM   #201 (permalink)
trdspectacoma is on a distinguished road
just have to wait maybe if you email them directly will help. also make sure that your owner name is exact to the information you put.
ex. in the phone I had first name then a space
on the form i did the exact but theirs did not register the space. I had to delete the space then it worked
trdspectacoma is offline
Old 08-19-2008, 01:37 PM   #202 (permalink)
QoreFunctions is on a distinguished road
Lightbulb from QoreFunctions
A new version of SmartphonePopUps has been released (dated 8/19/08) and is available for download from our website.
This version is a maintenance update and addresses the following:
  • Soft key labels restored when PopUp re-appears if dismissed by home key or keyboard lock.
  • PopUps re-appear sooner if dismissed by any key other than soft key
  • PopUp will now appear correctly for each new Outlook message when large batches are received during an Exchange or Standard ActiveSync session.
The update is free and can be installed over existing versions.
Nifty little apps that make life a little easier!
Download free trials at
www.qorefunctions.com
QoreFunctions is offline
The Following 3 Users Say Thank You to QoreFunctions For This Useful Post:
manbat (08-19-2008), rudeboy (08-19-2008), Shemmy (08-21-2008)
Old 08-20-2008, 10:59 PM   #203 (permalink)
manbat's Avatar
manbat is on a distinguished road
Default Works smoother with Photo Contact Pro 5
This version works smoother with PhotoContacts Pro 5 on my Q9m.
If Someone Helps You, Please Clickat the bottom of the post!
My HomeScreens: Click Here Here:http://www.everythingq.com/forum/q-home-screens-and-wallpapers/manbats-homescreens-22840.html
omef I
manbat is offline
Old 08-21-2008, 07:05 PM   #204 (permalink)
dafoxs's Avatar
after updating, I notice a delay from the time I get a text and the pop up appearing. in the past, I had none.
dafoxs is online now
Old 08-21-2008, 09:05 PM   #205 (permalink)
We have not seen this in any of our testing and that part of the code was not modified from the previous release in any way.
Old 08-21-2008, 09:56 PM   #206 (permalink)
dafoxs's Avatar
I timed it. from the time my count changes on my homescreen to the time my popup shows is 6 seconds. it use to close to 0.
Old 08-21-2008, 10:32 PM   #207 (permalink)
sulster's Avatar
sulster is on a distinguished road
The issue with Popups holding my phone hostage does seem to be fixed.
-potQ
sulster is online now
Old 08-22-2008, 12:35 AM   #208 (permalink)
TreeFrog's Avatar
dafox...no change for me on sms..but my wm5 takes 2-3 sec for the popup to generate..no biggie!
Sulster...oh yeah!
TreeFrog is online now
