Go Back   Motorola Q Forum | Everything Q > Other > Product Announcements
Old 07-06-2008, 03:18 PM   #141 (permalink)
sulster's Avatar
sulster is on a distinguished road
Originally Posted by dafoxs View Post
it works fine. sometimes when doing stuff on the phone, we are hitting keys and the pop up comes and it is the wrong key. this is where the problem comes in play.
Yeah, this is driving me batsh!t. If I walk in the kitchen and my phone is sitting there on the counter, with the screen off, I am apparently hitting the WRONG THING and then the Popup will won't let me do a darn thing....
Task Manager...trying to key down... DAMN POP UP... home button...task manager..try...POP UP....back key...POP UP... Home button... POP UP... you get the picture...
Did this ever get resolved? I've bought the app already...
sulster is online now
Old 07-06-2008, 03:25 PM   #142 (permalink)
dafoxs's Avatar
not yet. I got in the habbit of always hitting the left soft key all the time.
dafoxs is online now
Old 07-06-2008, 03:42 PM   #143 (permalink)
sulster's Avatar
Yuck. That just dismisses it, right? I mean, I have even managed to Delete the message from Outlook & the pop-up continues...
on a side note, Prosper--any chance of a picture for contacts w/o an assigned picture that doesn't look like the silouette of a James Bond Girl/Solid Gold dancer? it is a sweet skin, but us gals probably don't need that part. ;-)
Old 07-06-2008, 03:45 PM   #144 (permalink)
dafoxs's Avatar
you can change the picture to what ever you want, just have to over right the image. First you have to find what it was named and format.
Old 07-06-2008, 04:32 PM   #145 (permalink)
yea.. depending on the theme, it's called anonymous.png (extension may be different)
potQ9c
Old 07-06-2008, 05:43 PM   #146 (permalink)
sulster's Avatar
Yeah, I just don't have anything that looks "professional" enough to replace it with...
Old 07-06-2008, 06:06 PM   #147 (permalink)
Prosper's Avatar
@ rb
How are you processing with the darker theme? I might just go ahead and work little on it myself now that I'm stuck at home because Qore sounded little disappointed lately ... or are you nearly done?
Chose whichever one you like best.
Rename to anonymous.jpg and place it into the \Program Files\SPPopUps\Prosper-Business\320x240\ folder, so it overwrites the existing file.
Prosper is offline
Old 07-06-2008, 07:56 PM   #148 (permalink)
@ Prosper, nearly done.. but perhaps you can work on the voice mail one since I don't use that and also I can't test it..
or you can get cracking on the sliding panels hs for WM6.0..
potQ9c
Old 07-06-2008, 07:59 PM   #149 (permalink)
Prosper's Avatar
voice mail is basically the same as missed calls .. just replace 1 or 2 attributes ..
what wm6 sliding panel hs? :} sppopups sliding panel? :}
Prosper is offline
Old 07-06-2008, 10:06 PM   #150 (permalink)
i will resume tomorrow.
no the WM6.0 sliding panels hs you are making for me... not for SPPopUps.
