Originally Posted by dafoxs came across one clitch. If you hit the home key when the pop up is on the screen, there is no way to get rid of it. It keeps flashing. Have to reset phone. |
As we previously mentioned, pressing Dismiss or Dismiss All properly clears a PopUp. Pressing Home does nothing, eventually the PopUps will return. This was done by design.
We may add an option to treat Home key as Dismiss with a PopUp in the foreground.
Also, when the phone is in a locked state and a PopUp appears, you must hit * after pressing te right soft key in order to unlock the keyboard first before Messaging or Voice Mail launches.
We have tested this extensively with many devices and when the PopUps are properly Dismissed, there is no key lock delay.
