Go Back   Motorola Q Forum | Everything Q > Other > Off Topic
Old 04-05-2007, 02:15 PM   #1 (permalink)
Yester18's Avatar
Yester18 is on a distinguished road
Default saving webpages problem
Hopefully you can help me. My hardrive
was making noises and then died. I replaced it with a new one and only had my
documents backed up so I had to redo everything else from scratch. I got it up
and running and decided to get all the automatic updates, service packs,
security alerts, etc. from microsoft for my XP home operating system.
Now I'm having a problem saving webpages from the internet. With my old "zero
updates" XP version and I believe Internet Explorer 5? I would open file, click
save as, then see window with name(or change name of page), and save as (file
type) with drop down window with choices of HTML complete content, text, webpage
only, etc? I would save as HTML complete and it would save it as an HTML
Document on my computer. It would have the E internet explorer symbol, and also
a folder with all the details,info. Now when I try to save a webpage example
(msn.com) the "save as" drop down list only has File(html, htm), and Text with no other
choices. If I save as the File(html) choice it saves it on my computer as "File"
only and clicking it gives me the what do you want to open it with screen. It
shows up on my computer with the small white page with little colored squares
symbol. When opened it contains a bunch of script and that's it. When saved as
text it saves it on computer as "File" (ASPX) instead of "text Document" like it
use to. And it contains script when opened also. I've tried getting into
internet options and changing various settings with no luck. Settings are pretty
much back to IE default now. I'd appreciate any help you could give me. Thanks,
Yester18 is offline
Old 04-10-2007, 10:42 PM   #2 (permalink)
scubasteve's Avatar
scubasteve is on a distinguished road
Save it as (html,htm) then when u try and open it select "select program from list" and choose IE.
All right, brain, I don't like you and you don't like me - so let's just do this and I'll get back to killing you with beer. --Homer Simpson
Need a website built? Hit me up, looking to make some cash on the side filling my boredom...
scubasteve is offline
