Go Back   Motorola Q Forum | Everything Q > Other > Off Topic
Old 06-27-2008, 08:50 PM   #31 (permalink)
sherri's Avatar
sherri is on a distinguished road
Send a message via AIM to sherri
Rating or review Yeahhhh!!!
Ok, everyone! Thanks for all your help. I got it working!! Yeahhh!!! I reformatted the card in her phone. Then, I put the card in the adapter/put adapter in the pc/opened it in windows/found the file "my music". I went to the My Music folder (that hold my music on the pc), highlighted the songs Rachel wanted, clicked "copy". Then, back into the "my music" folder for the
storage card, clicked on "paste", and...voila! Howard Forums advised not to make any folders, just leave the music "loose" in the "my music folder.
I put the card into her phone, and it said: "Loading your music".
Rachel is dancing around the house!! Thank you all so much!!
Edit: This worked on Michael's (my 12 year old son) new Chocolate too!!
2 very happy kids, one extremely satisfied mom thanks tho EQ!! (I am now "cool" in my children's eyes....for a few minutes at least!!)
Sherri
(still have no clue what I'm doing, but at least I'm having fun doing it!!)
(If someone helps you out, click the "Thank You" by their name!!)
sherri is online now
Old 06-27-2008, 08:52 PM   #32 (permalink)
Tech.erella's Avatar
Tech.erella is on a distinguished road
All right! Glad everything worked out.
Tech.erella is offline
Old 06-27-2008, 08:52 PM   #33 (permalink)
awesome!!
glad you got it going
Old 06-27-2008, 09:11 PM   #34 (permalink)
sweet indeed..
Old 06-27-2008, 09:20 PM   #35 (permalink)
Good Work .............
bobby-n is offline
Old 06-27-2008, 10:48 PM   #36 (permalink)
sherri's Avatar
Rating or review Earphones....
Thanks again, everyone!
I finally found a use for my Radio Shack 3.5 mm - 2.5 mm adapter!! Works perfectly in Rachel's ENV2 (so I don't have to listen to Flo Rida over and over!!!)
She says it sounds as good as her i-pod nano!!
Hooray!!
Sherri
