Go Back   Motorola Q Forum | Everything Q > Other > Off Topic
Old 03-25-2008, 11:39 AM   #1 (permalink)
mbrevard's Avatar
mbrevard is on a distinguished road
Default Cable Box
We got a new entertainment center and the cable box has to go in it behind a solid door. I know I have seen a cable that you can plug into the box that has an eye on the end of it that is compatible with your remote. I am looking for one but I do not know how to search for it. I do not want to buy and infrared one because I think it will be a little out of the price range. Does anyone know what I am looking for? Thanks.
Mitch
My Blog
Twitter
Rockin The Q 9c With Verizon
mbrevard is offline
Old 03-25-2008, 12:52 PM   #2 (permalink)
PacoJr67's Avatar
I've seen that kind of thing before. Probably the best place to look for that would be through the manufacturer of the box. Although the infrared units aren't usually too terribly expensive (about $40 at radio shack)
PacoJr67 is offline
Old 03-25-2008, 12:59 PM   #3 (permalink)
mbrevard's Avatar
Thanks for the feedback
Mitch
My Blog
Twitter
mbrevard is offline
