Old 06-08-2007, 09:32 AM   #1 (permalink)
eefers is on a distinguished road
Default Went to Europe and Now My Email Won't Work, Help
Hi All,
I went to Europe for two weeks, came back and tried to download email with no luck. It says it's checking however many of 320 or something, but then nothing shows up in my inbox. I've tried taking the battery out, and multiple times have deleted the gmail account (I have my gmail set up as a POP3 acct), taken the battery out, restarted the phone and set up a new account. It keeps doing the same thing and won't download the messages. Can anyone help?
Thanks,
Emily
eefers is offline
Old 06-08-2007, 10:06 AM   #2 (permalink)
neutral's Avatar
neutral is on a distinguished road
Send a message via AIM to neutral
It's your phones way of telling you to go back to Europe.
Seriously though, try sorting through all the email on a PC. 320 Messages might be causing the Q to hang a bit. Is this POP3, Exchange?
Do you have your phone set to download headers only, or full messages?
neutral is offline
Old 06-08-2007, 10:08 AM   #3 (permalink)
Full messages. And yeah, I agree I should go back to europe. Probably a good idea to delete some messages....
Thanks.
eefers is offline
Old 06-08-2007, 10:10 AM   #4 (permalink)
neutral's Avatar
Thanks.
You probably have a message that is rather large, and it's causing this issue.
Connect via another method and remove said large message, OR change your Q to download headers only.
neutral is offline
Old 06-08-2007, 10:28 AM   #5 (permalink)
Default Still Not Working
Ok it checked all 12 then, still, nothing showed up in my inbox.
eefers is offline
