Old 01-30-2007, 07:05 PM   #1 (permalink)
darkcyber is on a distinguished road
Default Weather program with alerts (watches & warnings)
I'm looking for a weahter program that will run on my Q that will show watches and warnings or somehow send the same to your Q via the data (internet). I'm already running Memory-Map Radar and have Fizz Weather, but Fizz only list very very large cities and I'm not sure if it shows watches and warnings...if it does I haven't been able to figure it out.
I know my-cast.com does push type alerts, but will not work on the Q, surely there is something out there that will do push alerts via the internet...somehow.
Thanks!
darkcyber is offline
Old 01-30-2007, 08:38 PM   #2 (permalink)
MattB's Avatar
MattB is on a distinguished road
You know that you can enter your city by its zip code in Fizz Weather right? I only played around with the trial, but somewhere on the page where you select the city, you can click new city, then enter your zip and it will find you.
MattB is offline
Old 01-30-2007, 08:55 PM   #3 (permalink)
DLittle is on a distinguished road
Go to http://www.wunderground.com
from there, you can enter your city and setup email alerts, of all types. I use it all the time and just rec'd a winter weather advisory.
Doug
DLittle is offline
Old 01-31-2007, 12:30 AM   #4 (permalink)
bpaul24's Avatar
bpaul24 is on a distinguished road
Thanks Doug that is a great site.
bpaul24 is offline
Old 01-31-2007, 10:34 PM   #5 (permalink)
I have to tell you, I'm not impressed with Fizz Weather at all. If you want more than just a forecast...forget it. I've changed the cities and on the maps it still keeps showing somewhere in Europe.
As far as underground weather...that was one of the first ones I put in my favorites. What I meant, was I was looking for software apps that install on the Q. But thanks for the tip.
