Old 11-24-2006, 09:33 AM   #1 (permalink)
timmc11 is on a distinguished road
Default Weak battery
I've had my Q for about 3 months. The battery was tremendous for the first two months. I only had to charge it every 48 hours for the most part. But now I'll charge it over night, and barely use the phone and the battery will be dead by 9pm. Has anyone else had this experience? Is there anyway to get a new battery since it's only 3 months old?
timmc11 is offline
Old 11-24-2006, 07:48 PM   #2 (permalink)
kayak999 is on a distinguished road
I took mine back to the Verizon store. I have 2 batteries, and same experience only I am getting less time now since purchase end of August. Take it back and smile at them and get new batteries.
kayak999 is offline
Old 11-24-2006, 09:15 PM   #3 (permalink)
GWK
GWK is on a distinguished road
Have you checked to see if the IR Beam and Bluetooth are turned off. These two are major drains and I have found mine one a couple of time mysteriously. I do not have as much drain from the BT being on as the IR Beam.
GWK is offline
Old 11-24-2006, 09:24 PM   #4 (permalink)
Rhstevenson is on a distinguished road
Yeah seriously.. I had to receive some contacts from a person with a Palm pilot and so i enable IR and i forgot for a few days and my battery life changed significantly. I remembered when i read this post and now everythings back to normal! Phew!!!
QStuff - http://rhstevenson.com/q.html
Rhstevenson is offline
Old 11-25-2006, 06:57 AM   #5 (permalink)
mchero is on a distinguished road
Send a message via Skype™ to mchero
To turn off the IR you de-check "Receive incomming beams" in Settings/Conncetions/Beam correct?
RM
mchero is offline
Old 11-25-2006, 09:23 AM   #6 (permalink)
GWK
RM
yes, it's that simple
GWK is offline
Old 11-25-2006, 10:01 AM   #7 (permalink)
Cool, Thanks
mchero is offline
