So, I found that when using gmail on q, after the next "send are receive" The inbox email would vanish.
After searching on the forum I found one working which involved using two separate email accounts.
I found this fix on a different forum:
I just found this thread on the GMail help forums and, so far, it seems to be working. Emails don't disappear now on subsequent send/receives.
"Try this... in your email program on the pda you can normally choose
between downloading the whole rmail or just the header + x K's... try
this second option with a large amount there (999K)... not the most
elegant work around, but for me it works in the sense that emails are
not anymore flushed out from the pda inbox every time I synchronize!" http://groups.google.com/group/Gmail...9ae3d4750597a8
Test it out, everything is working for me, so far.
Works for me, may work for you too.
