Old 05-01-2007, 10:40 AM   #11 (permalink)
VTDr0p0ut's Avatar
One quick note : it has been my experience if my phone is plugged into the USB port turned OFF, the computer doesn't try to recognize it and it's OK and powers it correctly. If I have it turned on and plug it into a computer w/o ActiveSync, it will say "cannot find drivers" blah blah blah, and you say cancel (to not try to install any drivers) and then no power is given to the phone.
It could simply be that my wife's computer (which I experienced that on) could not provide enough juice to run & charge the phone.
VTDr0p0ut is offline
Old 05-01-2007, 12:14 PM   #12 (permalink)
mad3963 is on a distinguished road
ummm....im going out on a limb here...but is it a usb 2.0 port? if not then it probably wont send enough power to allow it to charge
FYI - A USB 1.1 port will charge the Q with no problem. At least, this is the case with the PC I am sitting at right at this very moment.
mad3963 is offline
Old 05-01-2007, 12:16 PM   #13 (permalink)
eh just a thought....
Old 05-01-2007, 04:10 PM   #14 (permalink)
michaelrou is on a distinguished road
Need Help
If you read the user manual, it states that the usb->usb-mini sync cable is for syncing and maintaining current battery life only. So to answer your question, it will not charge your phone. Use the wall plug->usb-mini cable for charging. Hope that helps.
michaelrou is offline
Old 05-01-2007, 04:15 PM   #15 (permalink)
it sure does charge the phone...i always get a charge complete message if i leave it plugged in to the computer for a while.
Old 05-01-2007, 04:16 PM   #16 (permalink)
Ok, I'm just telling you that's what the Moto Q user manual says.
Old 05-01-2007, 04:20 PM   #17 (permalink)
no its cool i know...
i guess there is only one more thing to try and thats just put active sync on the computer and see what it does...perhaps it allows the computer to see the device to charge it...
Old 05-01-2007, 04:38 PM   #18 (permalink)
If your battery has been completely drained, it cannot be charged via the USB cable plugged into the computer (this connection will only maintain current battery life). Use a wall charger or car charger to recharge the battery. Some computer USB ports provide a higher current than others, and
will provide more rapid charging.
-P. 27 Sprint Moto Q User Manual
So it looks like you should be able to charge your Q as long as you have a relatively high battery level to start with, but if its low to none, it will only maintain battery life. It also could be do to the the type of USB port you are trying to use (1.1 vs 2.0).
Old 05-01-2007, 05:17 PM   #19 (permalink)
gmplr831 is on a distinguished road
Send a message via AIM to gmplr831 Send a message via Yahoo to gmplr831
Originally Posted by GEPTRONIXDJS View Post
1 quick question and that is do you have to have the snyc software installed on a pc for the phone to charge thru the usb cable.....my phone now 3 weeks old will not charge thru the usb cable i have hooked up at my work pc and i do not have the sync software installed at work but it charges at home....any help would be greatly appreicated.....thanks
Make sure you are using a powered usb port. Because of the power, sometimes USB ports dont have enough power.
Jeff Hewitt - Sprint Q User
Ask me about technology, as i am a geek when it comes to this stuff!!
FRESH OUT OF REFERRALS FOR SPRINT! til 2-1-08!
If somebody helps you, boost their reputation.
gmplr831 is offline
