Old 11-18-2007, 02:22 PM   #1 (permalink)
Hvacman is on a distinguished road
Question HELP!!! Transmission Icon
Hello everyone. I have had my Verizon Q for about 2 weeks now and ever since I turned it on, about 10 mins after it has had the 2 arrows above the signal strength. The windows website inder icons says it means "data call in progress". Does anyone have any info on this. I go to task manager and "kill all" programs running. Even after this it is still there. I took a trip last night and when my phone went into extended network (not roam) it went away. After getting back around my house, it came back. Are my settings wrong or is this normal? Thanks all for the help.
Hvacman is offline
Old 11-18-2007, 02:38 PM   #2 (permalink)
khuas is on a distinguished road
I've seen the site to which you're referring and I don't think it's accurate:
http://www.microsoft.com/windowsmobi...one/icons.mspx
The best I can find is that the two arrows indicate that data access is available. If the phone does have an active data connection you should see a PDA icon, which does not even show on the above site.
(Note: I use Bell Mobility so the above info may not apply to Verizon)
khuas is offline
Old 11-18-2007, 03:17 PM   #3 (permalink)
piranah's Avatar
Originally Posted by khuas View Post
*snip*
I have VZ and khuas is correct. If you are actually connected, you have the pda icon, if there is the arrows, you have the availability to connect, or a connection was just ending or beginning. there are a couple ways to stop this.
One is to turn off your phone and turn it back on. the other is to do a reg hack to kill your data connection after a certain amount of time. Well ok, there are three. the third is to just ignore it and it will go away eventually, mine always does.
Be nice to the nerds, chances are you already work for one..
if ive helped you, help me stay out of jail and donate ...
piranah is offline
Old 11-18-2007, 06:50 PM   #4 (permalink)
i do believe we talked about this over PM already...and i think i said what khuas & piranah said
so i guess now with 3 confirmed answer of the samething you should be good to go right
