Old 10-11-2007, 03:16 PM   #1 (permalink)
Default System Text Color
so i decided to change my 'in call screen' to a dark one and well the text is black (doesnt work very well) does anyone out there know how to change the system text color (i guess thats what its called) basically want white text for the screens with the following images:
Old 10-11-2007, 03:16 PM   #2 (permalink)
and this file:
Old 10-11-2007, 03:21 PM   #3 (permalink)
possibly COLOR_ALERTTITLE ? those freaking color codes always confuse the heck out of me.
Old 10-11-2007, 03:22 PM   #4 (permalink)
that stuff would be in the homescreen file?
Old 10-11-2007, 03:25 PM   #5 (permalink)
if not add it to the color scheme, i don;t use an external color scheme, do you ? my guess is no so it should be in the scheme part of the .xml. add:
<color name="COLOR_ALERTTITLE" value="#xxxxxx"/>
where xxxxxx = your 6 digit desired color.
Old 10-11-2007, 03:27 PM   #6 (permalink)
i will give that a go!
Old 10-11-2007, 03:30 PM   #7 (permalink)
i just checked my scheme and that code is already there and its setup with the color i want!
hmmmmz
Old 10-11-2007, 03:36 PM   #8 (permalink)
TreeFrog's Avatar
Some screens are un-changeable....I just start changing everything with "text" in it.. 1by1, and writing down what they were of course!!
TreeFrog is online now
Old 10-11-2007, 03:37 PM   #9 (permalink)
i was over at qusers.com (since i remember seeing a ton of these screens posted there many moons ago) and one guy there had blue text!
im not a member over there so i cant post but im sure its possible....
just wish i knew or someone else here knew
maybe prosper???
Old 10-11-2007, 03:40 PM   #10 (permalink)
maybe prosper???
i'm a member there... what post ?
n99hockey (10-11-2007)
