Outlook will pull your contacts from your phone using ActiveSync or that Vista App (I always forget the name of it). The import/export feature is to pull contacts from data files and other applications.
Just to make sure that you don't have ActiveSync pulling too much data. Set up the initial profile to just sync the contacts. This should take care of the issue for you.
Good Luck
(In this forum, somethimes I feel like using the greeting from the not-so-great movie 'Robot Jox' ---"Crash 'n' Burn"-----If you have seen that movie, I feel pity for you like I already do for myself.)
Kobutah
"I do not regret the things I've done, but those I did not do!"
