Old 06-12-2008, 10:45 PM   #1 (permalink)
JonQ is on a distinguished road
Default Storage Card not seen
I just got a 8gb card and phone soes not see it(unknown). Have checked and no update is available from sprint. Has anyone got a 8gb card to work? Is there a way to get Windows Mobile 6 without getting a new phone?
JonQ is offline
Old 06-13-2008, 10:49 AM   #2 (permalink)
ryant35's Avatar
ryant35 is on a distinguished road
You have to download the SDHC.cab file and load it so you can use an SD card over 2gb. I know it works with my 4gb card, and I've heard about it working on the larger ones.
http://rapidshare.com/files/72977206/SDHC.zip
ryant35 is online now
Old 06-13-2008, 10:49 AM   #3 (permalink)
ryant35's Avatar
And no WM6 upgrades so far...
Old 06-13-2008, 10:50 AM   #4 (permalink)
and no to the 2nd question
bobby-n is offline
Old 06-18-2008, 02:22 PM   #5 (permalink)
Please tell me the correct way to install. The phone says not a valid Windows CE application. Please help!!
J
JonQ is offline
Old 06-19-2008, 01:33 AM   #6 (permalink)
ryant35's Avatar
Did you copy the .cab file to your phone and run it from there? That's how it works.
Old 06-19-2008, 10:00 AM   #7 (permalink)
I unzipped it and I do not see a .cab file only a .exe file. Sorry what am I doing wrong!? Where are you supposed to put it (what file) on the phone? I really do appreciate your help!
JonQ is offline
Old 06-19-2008, 10:16 AM   #8 (permalink)
ryant35's Avatar
I normally put my program install files on my storage card, but obviously you can't. Plug your phone into your pc and copy via usb, anywhere is fine, I would drop it into my documents so you can find it. Copy the whole .cab file and navigate to it with your phone's file manager and load it. the cab files show up as a winrar compressed file, but that file is what your phone needs to load the exe file inside.
The Following User Says Thank You to ryant35 For This Useful Post:
JonQ (06-19-2008)
Old 06-19-2008, 10:51 PM   #9 (permalink)
Rating or review
WinZip was the problem. Uninstalled and had no more problems. The only issue now is that the phone thinks it is a 4gb not an 8gb. Any other ideas?
Thanks!!
JonQ is offline
Old 06-19-2008, 11:04 PM   #10 (permalink)
ryant35's Avatar
Thanks!!
Reformat on the Q?
I don't know, even if the phone thinks it's small it won't stop you from loading your media & files via USB from your computer.
I only have a 4gb card to I don't know beyond that.
