Old 05-08-2007, 06:29 PM   #1 (permalink)
ericv021969 is on a distinguished road
Default Storage card
i used file mangr get unknown mem is there any other way to check ur storage card thnx for the help
ericv021969 is offline
Old 05-08-2007, 07:23 PM   #2 (permalink)
check your storage card for what?
to see them amount of memory left you can go to start-->system tools-->memory manager...
if this isnt what your looking for let us know!
just a note for the future...you only need to post one message
Old 05-08-2007, 07:47 PM   #3 (permalink)
went to mem mang when i get there i get unknown
Old 05-08-2007, 07:51 PM   #4 (permalink)
have you tried to format it on your PC or on the Q?
Old 05-08-2007, 09:14 PM   #5 (permalink)
yes on the q but not the pc how u do that on pc
Old 05-08-2007, 09:17 PM   #6 (permalink)
im tryin to find out my q req the stor card
Old 05-08-2007, 09:21 PM   #7 (permalink)
FourTwenSesh's Avatar
Eric bro, we can help you out, but we need to know what is wrong first, k? So try to give a detailed description of your problem so that n99hockey can fix it!
FourTwenSesh is offline
Old 05-08-2007, 09:33 PM   #8 (permalink)
k the mem card is in when i go to check to see if its there in sys setts it display storage card unknown
