click sound is good If there is a small click sound when you try to play a ringer, I think that's a good sign. Your phone might be just fine.
Have you looked at your profiles under settings? Hover over a profile, click menu, and check to see that you have all of the sound categories set to 1) make a sound and 2) a sound volume of 3 or higher. Make sure the profile is checked, and also check the scrool wheel volume once before you try again....
Tell us is this doesn't work...
p.s. the Q9 is what you make of it... most of us find out the hard way. |
