Old 11-07-2006, 11:41 AM   #1 (permalink)
manupie is on a distinguished road
Default Silencing incoming ringtone
i recieve text messages all the time and i can't figure out a way to mute the ringtone as soon pick up the phone. I have read i can use the scroll on the side but it doesn't work. Any other suggestions? any buttons to mute the ringtone?
Sometimes i can read the whole message before it stops ringing!
thanks
manupie is offline
Old 11-07-2006, 01:34 PM   #2 (permalink)
inf3st's Avatar
inf3st is on a distinguished road
The only options for text msg's is create a shorter version of the ringtone. There is no way of stopping it.
inf3st is offline
Old 11-07-2006, 03:48 PM   #3 (permalink)
is there an easy way to do this? i am just using the current ringtones that come with the phone
thanks for the reply
manupie is offline
Old 11-08-2006, 10:19 AM   #4 (permalink)
inf3st's Avatar
Any ringtone software should be able to handle it.
inf3st is offline
Old 11-08-2006, 06:58 PM   #5 (permalink)
TAG1976's Avatar
TAG1976 is on a distinguished road
Just use an error message tone. Its like one beep, and you can barely hear it.
-Tom
-Tom
TAG1976 is offline
Old 11-09-2006, 06:49 AM   #6 (permalink)
Dubbal R is on a distinguished road
Send a message via MSN to Dubbal R
...or you could go into your profile setting and just set your "Notification" to vibrate.
Hope that helps
--Dubbal R
If you can't be good, be good at it
Hit Me Up!
Dubbal R is offline
Old 11-09-2006, 11:56 PM   #7 (permalink)
larsdennert's Avatar
Rotate the wheel to silence it. Don't push it in if that's what you are doing.
larsdennert is offline
Old 11-10-2006, 06:20 AM   #8 (permalink)
inf3st's Avatar
That won't work for texttones
inf3st is offline
Old 12-14-2006, 02:05 PM   #9 (permalink)
NateX is on a distinguished road
It would have been nice if the manual said to rotate the wheel to silence the call - it only says "use the thumb wheel to turn the ringer off" which I interpreted as pushing the thumbwheel which only answers the call. Anyway, now that I've figured out how to silence the ringer by rotating the thumb wheel, is there a way to disable the ability to answer a call by pushing it?
Thanks!
NateX is offline
Old 12-15-2006, 03:20 AM   #10 (permalink)
You can set the phone to only answer using the send key. Then pushing the scroll wheel in won't answer. You can also use the right menu button to immediately send someone to voicemail.
