Old 01-29-2008, 10:25 AM   #1 (permalink)
mbrevard's Avatar
mbrevard is on a distinguished road
Default Signal Icon
I am sure it is listed somewhere else on here but I can not seem to find it with my search keywords.
What is the circle with a diagonal cut out of it at the top right of the screen where the signal reading should be? This thing pops up daily and when it is up I can not place any phone calls. Thanks.
Mitch
Rockin The Q 9c With Verizon
Join The EverythingQ User Map
mbrevard is offline
Old 01-29-2008, 10:27 AM   #2 (permalink)
means your phone is turned off...
hold down the home key and go to wireless manager and turn the phone on
mbrevard (01-29-2008)
Old 01-29-2008, 10:29 AM   #3 (permalink)
mbrevard's Avatar
Great. How do I keep this from happening again. It seems to happen everyday at 5:30. The reason I notice this is I leave work at this time and attempt to call my wife and never can.
Mitch
mbrevard is offline
Old 01-29-2008, 10:31 AM   #4 (permalink)
for some more icons see here. (side note: list turns out not to be complete as i found out yesterday when i had an icon not listed appearing.. i figured it out though)
Old 01-29-2008, 10:43 AM   #5 (permalink)
thats a very good question
it will happen if for some reason you are running an alarm program that is programed to shut it off at that time
or you go in a subway or place with no signal for an extended period of time
Old 01-29-2008, 10:52 AM   #6 (permalink)
mbrevard's Avatar
That may be it. I have set my phone to have an appointment everyday from 8:30-5:30 and have the profile set to auto so the phone will go to vibrate all day while I am at work. I wonder if this is triggering it? It has only been happening for the past couple of weeks and I have had this set for a few months now. Weird. I hate that this is happening. I wonder if there is a bug or something in it?
Mitch
mbrevard is offline
Old 01-29-2008, 10:54 AM   #7 (permalink)
turn off the appointment setting for today and just set it to vibrate manually and test it out at 530 and see what happens
Old 01-29-2008, 11:06 AM   #8 (permalink)
mbrevard's Avatar
Nice idea. I will try this and will update this evening.
Mitch
mbrevard is offline
Old 01-29-2008, 11:09 AM   #9 (permalink)
excellent
looking forward to your findings!
Old 02-06-2008, 10:35 AM   #10 (permalink)
mbrevard's Avatar
Sorry for not updating earlier but everyone has been sick at my house for the past week.
That day I removed the appointment and did not have the problem at 5:30 like I used to but I did have it at 3:00 and 4:00. That afternoon on the way home I called VZ and they basically told me to do a reset that would take my phone back to factory settings. Before I was able to do that the Q had a little run in with some water (story posted here) and after it reset itself it is working great.
Mitch
mbrevard is offline
