Old 04-24-2008, 07:08 PM   #1 (permalink)
sb54635 is on a distinguished road
Default Setting icon missing
My settings icon is missing all of a sudden. I can't get to it in the folders or on the start menu. any suggestions as to what I did and how to fix this?
sb54635 is offline
Old 04-24-2008, 07:27 PM   #2 (permalink)
what did you do ? can you broswe to the \Windows\Start Menu\ and check if the link is there and else recreate it.
potQ.
Old 04-24-2008, 07:37 PM   #3 (permalink)
Smile
potQ.
I don't think I did anything. I can go to windows/start menu/ and I don't see it there. Is there some way to get it back?
sb54635 is offline
Old 04-24-2008, 08:36 PM   #4 (permalink)
on my Q1 i have a settings.lnk in the Windows root.. see if you have that and if you do copy it to the Start Menu folder.
potQ.
