Seriously need help Well as I have done before, I needed to do a master reset. Before doing so, I copied my pim.vol to my desktop pc for backup. I reset my phone and it worked fine. I went in, renamed the new pim.vol to pim.old, copied over the correct pim.vol, and restarted the phone.
I cannot do anything - I just get a cprog.exe error and the phone is totally bricked. Doesn't even get service.
I can reverse this by replacing the empty pim.vol, but that effectively renders my phone worthless without my contacts.
I have done this backup method before and it has worked perfectly, I do not understand what is preventing my phone from recognizing the old PIM with all of my information on it.
I also tried using total commander to eliminate the problem being with my desktop PC.
I NEED my old pim.vol to work.
Any ideas? |
