Old 01-28-2008, 08:49 PM   #11 (permalink)
darkcyber is on a distinguished road
I have only had to do what I would say is moderate use of my Q while using this battery. Some talking and a good bit of graphical surfing.
To sum things up, if you have a Motorola Q, you need this battery...period! I have used the 1640 mah battery for over a year and would get so mad because my dang battery would be near dead by 4-6 pm on some days. Some days it would make it until bedtime.
Right now, I am on my forth day with this one and it is 8:00 pm and I am still showing 50% battery life. This is off of one single charge, the very first charge since I have owned the battery. This battery comes with a new cover and it does stick out further than the 1640 cover, but I do not care, I love having battery life.
THIS IS JUST INCREDIBLE!
I purchased the blue Verizon case when I bought may phone and it still fits perfect in it, even with this 3200 battery.
darkcyber is offline
Old 01-28-2008, 11:42 PM   #12 (permalink)
Krunk_Kracker is on a distinguished road
Send a message via AIM to Krunk_Kracker Send a message via MSN to Krunk_Kracker
I actually came into this thread to ask about the case....which case is it you have? I have a plastic holster that holds the phone face in, but are there any other cases that will fit this big ass battery?
Krunk_Kracker is offline
Old 01-29-2008, 08:31 PM   #13 (permalink)
Ok, today is day 5 and my Q started out with 25% battery life and now it is 7:30 pm and I am still showing 25% battery life, again this is from one charge.
Case question:
My Q came with the standard black leather/vinyl case, which I have not used. I purchased one from the Verizon store the day I bought my Q. It is a blue leather case with Verizon on the metal piece, that has a single strap over the top middle part of it and snaps on the front. The case pulls apart at the top for my Q to slide down into it. On the inside is a label that says:
USA Wireless PDAPOUCHBLU-B. Here is a picture of my phone with the battery and my case:
This image is hosted at photobucket, if it is to big or a problem, let me know and I can delete it or change it.
I hope that helps!
The Following 2 Users Say Thank You to darkcyber For This Useful Post:
dukeofbluz (01-30-2008), sulster (02-05-2008)
Old 01-29-2008, 09:20 PM   #14 (permalink)
wow that makes your q look so big idk if id buy it jus cuz that reason
bobby-n is offline
Old 01-29-2008, 09:28 PM   #15 (permalink)
Well, I have this one now,
http://store.everythingq.com/content...4-24--1013.htm
And of course that wouldn't be a problem, but I hate holsters because they mutilate the phone case.
I have the 1550 extended battery and plane on getting this 3200 but I want something like this,
http://store.everythingq.com/content...4-20--3161.htm
But I just dont know if it will fit...
Old 01-29-2008, 10:49 PM   #16 (permalink)
I really don't care how big it makes my Q, I just love being able to use my Q without having to worry my battery will die any minute...that's priceless
Krunk_Kracker,
That case says it requires the slim line battery and door, so I doubt it will work with this 3200 mah battery. But nice looking case.
Old 01-29-2008, 11:09 PM   #17 (permalink)
TarHeelsRule!'s Avatar
TarHeelsRule! is on a distinguished road
I had the body glove with my original Q. When I got the Q9c it wouldn't fit. It says that it will but the fit was too snug for my liking. I haven't been able to find a case that I like to fit the Q9c with the extended battery.
TarHeelsRule! is online now
Old 01-31-2008, 12:36 PM   #18 (permalink)
saa001 is on a distinguished road
[I have had the 3200mah battery and I use a soft neoprene case for it (it works well with many different phones).
The battery is well worth the cost. I only use my cell phone (no land line for many years). While I can go literally days without charging my phone, I do so at least every other day.
saa001 is offline
Old 02-02-2008, 02:37 PM   #19 (permalink)
Matteo86 is on a distinguished road
darkcyber, when you get a chance could you take another pic with the Q standing up. I'm curious how much bigger it is than the extended (i know its 4mm but want a visual if possible.)
And your absolutely right about the moto 1640..barely cuts a day pending usage.
Thanks
Matteo86 is offline
Old 02-03-2008, 02:08 AM   #20 (permalink)
larsdennert's Avatar
I came from the standard battery to the Seidio 2000mah and it's been great not having to charge the phone everyday or worry about it going dead when I'm out. I struggled whether to get the 3200 and decided it was just too JLo for me.
http://www.larsdennert.com
larsdennert is offline
