Old 03-08-2007, 11:32 AM   #1 (permalink)
OnTheEdge is on a distinguished road
Default SD Card: Storage Card2
I'm having a problem with my SD card. I had a bunch of stuff on my card at one point. I pulled the card while the phone was on (probably shouldn't have done this). My applications and pictures/movies etc... disappeared. I looked at the card through ActiveSync and saw two instances of the SD card
Storage Card
Storage Card2
I opened up Storage Card2 and, sure enough, there was 'Program Files'.
I cut and pasted it back to Storage Card and everything came back. Anyone know how to get rid of the 2 instances??
OnTheEdge is offline
Old 03-08-2007, 01:39 PM   #2 (permalink)
211655 is on a distinguished road
i had same issue on myppc once.
explore your device using the active sync. rename storage card 2 to storage card. if you have already have a storage card. copy the contents into hard drive of ur pc and then delete the storage card
sumtimes wm5 creates a storage card folder using the phone ram.
211655 is offline
