Old 07-20-2007, 03:11 AM   #1 (permalink)
Q Status is on a distinguished road
Default right menu
I can not seem to delete or get rid of the (Right Menu) program from my Q
Q Status is offline
Old 07-20-2007, 09:31 AM   #2 (permalink)
check out my posts in the right menu thread about removing the program
-Sent from my Q
Old 07-21-2007, 05:25 PM   #3 (permalink)
SloppyGoat is on a distinguished road
I just did the same damn thing, and I can't find your thread on removing it. I deleted all traces of it, and now it's gone, but my right key no longer opens contacts! WTF?!
SloppyGoat is offline
Old 07-21-2007, 05:32 PM   #4 (permalink)
thats because you didnt turn it off first..my thread on the software tells you how...
put all files back..go to the editor then go to options and uncheck 'use' so it turns off the program...then you delete the program files
-Sent from my Q
Old 07-21-2007, 05:36 PM   #5 (permalink)
I tried reinstalling it. Here's what happened. It's there, and I can run it, but there is no start menu icon anymore, and my right key still doesn't work! How do I remap the damn button to open my contacts again? GRRRR!!!
Ok, nevermind. I think I got it. I really hate programs that don't have an uninstall that leaves everything the way it was!
Old 07-21-2007, 05:48 PM   #6 (permalink)
ok so you got it?
-Sent from my Q
Old 07-21-2007, 05:53 PM   #7 (permalink)
Yep, thanks. Like you said, I just had to uncheck the use box first, and kill it. Thanks! I was ready to scour the registry for the stupid key path. :D
Old 07-21-2007, 06:03 PM   #8 (permalink)
ok great just wanted to make sure
-Sent from my Q
Old 07-21-2007, 08:16 PM   #9 (permalink)
Originally Posted by SloppyGoat View Post
*SNIP* Ok, nevermind. I think I got it. I really hate programs that don't have an uninstall that leaves everything the way it was!
from what i understand it is a user related issue since you didn't first stop the program from running :}
Old 07-25-2007, 10:35 PM   #10 (permalink)
I think every program should have an uninstall and do whatever it needs to do automatically....expecially if it's god damn trialware!!! There was no indication that it wasn't free, where I downloaded it. It wasn't portrayed as a trial.
