Old 07-21-2007, 05:30 PM   #1 (permalink)
buzzzqwert is on a distinguished road
Default Return key doesn't work correctly
If I'm typing and want to move down a line or more I thought pressing the return (or enter) key would do it but it doesn't. On my Q if I open a note in Phatnotes and after typing I hit the return key it takes me off of the page I'm typing on and takes me back to the note topic list (same problem with List Pro). If I press the return key twice, it takes me from the the note back to the topic page and back to the note. What the heck is going on ?
buzzzqwert is offline
Old 07-22-2007, 11:12 AM   #2 (permalink)
Which key are you pressing? The key to the right of the "L" is the return key (or use the D-Pad center button). Are you pressng the "Back" key (the one to the left of the power button)? Both have arrows ponting to the left.
-- Motorola Q, WM5, Verizonwireless, U.S.A. --
scottjb is offline
Old 07-22-2007, 02:24 PM   #3 (permalink)
The key to the right of the "L". For some reason it now works (as does the center button) when I'm using Phatnotes. It still doesn't work correctly on List Pro. Hard to figure out what happened when it didn't work for 2-3 days and then all of a sudden it does and why it (either button) doesn't work in List Pro.
