Originally Posted by bobstemm I've dropped my Q on cement (twice) and everything works fine except the little rectangle cover on the back (located next to the camera lens) popped off and I can't find it. Is there any resource for getting a replacement part? |
Not something that I would get overly worried about. It's the cover for the external antenna. You might try going to your local provider and see if they will give you a cover from a handset that's being sent back. I don't feel that leaving it uncovered would hurt anything. If it just annoys you and you can't get a replacement for free then you can try placing a piece of duct tape over it :P
