Originally Posted by tsantacruz I have a problem removing an application. It is called Right Menu Key and I could not figure out how to remove it so I went in the registry editor and removed everythign that had that registry in it. Now the program does not work, and it is still showing a generic white icon. |
Didn't the
Remove Programs settings applet work for Right Menu? If you didn't try that, you should have.
Originally Posted by tsantacruz Does anyone know how to remove this and also get back my contact shortcut that used to be on the bottom right of home screen. The right menu key program replaced the functionality of that button. |
The best way would probably be to install the program again, then uninstall it the correct way.
If that doesn't work, or if it still leaves an icon in the Start Menu, go to
\Windows\Start Menu to remove the icon.
Steve
