Old 11-09-2006, 02:53 AM   #1 (permalink)
JessJenn's Avatar
JessJenn is on a distinguished road
Default Receive the Entire Body of Email
I get emails that are chopped off and I have to select the option to download the entire email. Is there a way to receive the entire body of the email? Registry hack perhaps?
Thanks!
JessJenn is offline
Old 11-09-2006, 06:40 AM   #2 (permalink)
Dubbal R is on a distinguished road
Send a message via MSN to Dubbal R
If you go into "Account Options" of the email service that you are using and go through the setups, there should be the option where you select how much of the email that is downloaded. Choose "Entire Message" and you should be good.
Hope this helps
--Dubbal R
If you can't be good, be good at it
Hit Me Up!
Dubbal R is offline
Old 11-09-2006, 02:51 PM   #3 (permalink)
sellrooms is on a distinguished road
Default Thank you
Hope this helps
Thanks so much. That was bothering me too!
sellrooms is offline
Old 11-09-2006, 03:16 PM   #4 (permalink)
Brewzer is on a distinguished road
I guess i need a bit more info. I use outlook and it downloads my whole message. It is only on my Q that i get only part of it. I am using vzn wireless sync to get my emails on the Q. Where would i go to make it so i can get whole email on my Q. Thanks!
Brewzer is offline
Old 11-09-2006, 04:14 PM   #5 (permalink)
peter is on a distinguished road
Default same issue
I have the same issue. Those instructions work for my other email setups but I cant seem to access the options for exchange email? should i re-build the account and hope those options show up as part of the new build?
peter is offline
Old 11-09-2006, 04:17 PM   #6 (permalink)
JessJenn's Avatar
Hope this helps
Thanks for the feedback. Does this work for emails that are synched to an Exchange server? Because POP3 (non-Exchange server) emails come in full. It's when I get emails from Exchange that are synched that I get part of it.
JessJenn is offline
Old 11-09-2006, 04:22 PM   #7 (permalink)
I think so, if I figure out how to fix this I will let you know.
peter is offline
Old 11-09-2006, 06:19 PM   #8 (permalink)
spindoctor is on a distinguished road
Hope this helps
I use wireless sync and dont have 'account options' for my outlook mail. Should I?
spindoctor is offline
Old 11-09-2006, 08:33 PM   #9 (permalink)
I use POP3 and don't get full emails?
Brewzer is offline
Old 11-09-2006, 11:18 PM   #10 (permalink)
larsdennert's Avatar
Try changing the email settings in activesync. There similar ones there as the pop settings have.
larsdennert is offline
