Originally Posted by HollyKay I have had my Q all of 2 days, and I installed a 3rd party app to make the start menu different, and it didn't work. So I deleted the files, but now the right soft key that was assigned to Contacts gives me:
Alert: Error opening the shortcut or locating the target filename.
Any help?
Thanks in advance.
Holly |
is it the right menu software that i posted?
if so you have to put the files back on the Q...then go in to the program and go to options and uncheck the box that says 'use' so the button will go back to normal...
then you can delete the files...if you dont do that you will get that error message
