Old 10-08-2007, 06:58 PM   #1 (permalink)
MattB's Avatar
MattB is on a distinguished road
Default RDC From WM6 Works!!!
Not really sure how well yet, but I have been able to connect to one of my servers and load the desktop no problem. I just cant navigate around the screen. I did a quick search to see if this has already been covered, but I dont think so. See it and download it from here:
http://lifehacker.com/software/featu...one-307607.php
MattB is offline
Old 10-08-2007, 07:13 PM   #2 (permalink)
nags's Avatar
nags is on a distinguished road
Send a message via AIM to nags
Trying it now
http://www.the-nags.com
nags is offline
Old 10-08-2007, 07:15 PM   #3 (permalink)
MattB's Avatar
Damn it, i think it only works with touchscreen devices. This would have been soooooo cool if it worked well on the Q.
MattB is offline
Old 10-08-2007, 07:18 PM   #4 (permalink)
nags's Avatar
I get a connection error anytime I try to connect
nags is offline
Old 10-08-2007, 07:20 PM   #5 (permalink)
MattB's Avatar
I've connected to 3 of my servers (all that already are set up to allow rdc connections) I can log in with no problem, but once i get to the desktop I cant do anything.
MattB is offline
Old 10-08-2007, 07:25 PM   #6 (permalink)
nags's Avatar
Weird.. I live on remote desktop.. use it all the time. I couldn't connect using the domain name or direct ip
nags is offline
Old 10-08-2007, 07:30 PM   #7 (permalink)
MattB's Avatar
I was able to connect with either IP or Name. I dont know why. You're not still plugged into your PC are you?
MattB is offline
Old 10-08-2007, 10:55 PM   #8 (permalink)
MattB's Avatar
Very exciting, i was able to make it work!! You need to install sphelper which gives you a mouse cursur allowing you to control the desktop. it certainly isnt the best experience, but it will be a huge help when i need to reboot a server or something on the road.
MattB is offline
Old 10-09-2007, 07:05 PM   #9 (permalink)
MattB's Avatar
Why dont posts in here make it to the new post page?
MattB is offline
