Originally Posted by chugg MIne did come with the adaptor sleeve but to transfer files on it from the computer instead of using the wired active sync (because if you normally do wireless it screws things up) there is some kinda wire you need to get. THis is what I am looking for. |
If you have the adapter sleeve, then you can use a USB card reader that accepts either miniSD or SD.
Like this:
http://www.supermediastore.com/phili...der-black.html
It's unnecessary though, because as
VTDr0p0ut states, you can just use the Q as your card reader, by connecting it to your PC w/ the supplied USB cable, and use the "Explore Smartphone" feature of ActiveSync.
(I seems this is the best way to go, as some datatypes appear to need some conversion for smartphone use, which ActiveSync does)
