If you go into WirelessSync and enalbe ActiveSync, that MIGHT fix the problem (could also be a firewall issue though). Fortunately, I don't use the VZW Q anymore, so I can't give you menu-by-menu detail. Another option is if you have Bluetooth on your computer, you can just send the files using BT PAN/OBEX. This can simply be done by right-clicking a file -> Send to -> Bluetooth Device and follow the prompts. If your phone isn't in your computers PAN, then just make sure it's set to be discoverable.
If THAT doesn't work, you could always inistall Total Commander and put the files on a publicly accessible FTP server and download the docs via FTP (probably waaaaayy too much trouble for whatever benefit you gain). |
