Old 10-23-2007, 10:13 AM   #1 (permalink)
Binet is on a distinguished road
Default Questions about Contacts.
Hey there everyone, recently signed up, and this site has been a great help for me! My Q is really fast and all the information on this site has helped me a lot so far in understanding how the whole Windows mobile kinda thing goes. I am on Telus Mobility in Canada, and I am coming from the Nokia 6265i. I was able to back up and get all my files from the Nokia, using Nokia Pc Suite, and have all my contacts in a seperate file in a folder. I am not at home right now, and am not sure the file extension, but I just wanted to know if there was an easy way to get them onto the Q, as I don't really have the time to re-add 247 contacts, most with 2 numbers each. Is there a program that would let me organize and add my contacts on the computer, and then sync them with the Q? Any help would be appreciated!
Thanks.
Binet is offline
Old 10-23-2007, 10:32 AM   #2 (permalink)
welcome aboard...
you could have asked the carrier to transfer contacts... do you happen to use Outlook (full version), that would be the easiest. secondly there is Jeyo Companion, you might be able depending of the file format you have import a .xml file.
