Old 10-04-2007, 07:41 PM   #1 (permalink)
Flippnoyballer is on a distinguished road
Default Question about AIM
hey i read the FAQ's about aimand it stated that there is a way to download aim on your phone. Does anyone have step by step instructions to do it?or any pictres to accomplis this?
and a few other questions
-for most of the downloads here give the links to the site, do i have to go on the site from my phone?or do i open the site on my computer then download it?if so do i use a usb cable to get it to my phone?or sync?etc
this is my first post here, and i dont know much about my Q so please dont be too brutal
Flippnoyballer is offline
Old 10-04-2007, 08:52 PM   #2 (permalink)
welcome aboard... some applications come as a .cab, that is a file you can download to the Q and open/execute with the build-in File Manager. if the file is a .zip/.rar they need to be unpacked with Winzip/Winrar for which you need 3rd party software... and then there are .exe files, some you need to install via a pc with the Q connected (Active Sync). lastly there are .msi files, those also need to be installed using a pc.
(rarely but out there are .exe files that you run on the Q, if that is the case it is usually mentioned)
hope this helps..
Old 10-04-2007, 09:04 PM   #3 (permalink)
hope this helps..
the thing is, i tried before to download sync, but i couldnt figure it out, is there a thread here with step by step instructions, ive been reading a couple threads arund here and ive been totally lost
Old 10-04-2007, 09:20 PM   #4 (permalink)
sync ? do you mean Active Sync ? there are not enough steps to make a step by step :}
Old 10-04-2007, 10:03 PM   #5 (permalink)
yeah i ment active sync haha, well wen i try to sync my phone it cant find the thing
