Old 05-10-2007, 08:28 PM   #11 (permalink)
itzhobbes is on a distinguished road
mfer, if you installed the Sprint OnDemand, it will install the .net framework for you. I also have a Sprint Q. Mine is up and running. Just a suggestion.
itzhobbes is offline
Old 05-11-2007, 12:22 AM   #12 (permalink)
ttboy44 is on a distinguished road
which update is that. what release? I have not seen one since March.
ttboy44 is offline
Old 05-11-2007, 08:31 AM   #13 (permalink)
regression is on a distinguished road
The update I was referring to is here and click on "Software Update". After applying this update, I am able to receive calls while on the Internet without changing any settings in the Field Test Menu.
http://tinyurl.com/rhz7h
regression is online now
Old 05-11-2007, 02:00 PM   #14 (permalink)
mfer is on a distinguished road
So you are saying that I can install the hacked version of document program extracted from WM6 without any issues because Sprint OnDemand is the newest .NET framework?
mfer is offline
Old 05-12-2007, 04:30 AM   #15 (permalink)
larsdennert's Avatar
You only need .net cf2 if you are using the create new document addin posted on modaco (I think). Otherwise Office WM6 installs and runs right from the cab file.
Ptab is the third choice for Excel functionality. Also a great program.
http://www.larsdennert.com
larsdennert is offline
Old 06-07-2007, 05:04 PM   #16 (permalink)
kalina's Avatar
kalina is on a distinguished road
Question Which framework?
I was trying to run a program that needed the 2.0 sp2 version. I have recently installed this version. I tried to open my On Demand, and it wants to load another framework, which I am sure is not the latest, because I had already installed On Demand once before my master reset. And I couldn't use the program that reqiured 2.0 because On Demand was using a lower version.
What do you think? I'm seriously thinking OnDemand may take a leap for me, because I like the 2.0sp2 version and the program that uses it. I know for sure that OnDemand is not loading the latest version.
kalina is offline
Old 06-09-2007, 03:39 AM   #17 (permalink)
Metsown is on a distinguished road
has anyone found a way to use AIM on the Q yet??
I dont want to pay 25 bucks or whatever it is to get that IM+ thing, and would love to have AIM on my Q
Metsown is offline
Old 06-09-2007, 11:09 AM   #18 (permalink)
For AIM, use Octro talk. It is free and works with Yahoo, AIM, MSN Messenger and Google Talk. You need a Google account to log in, then you can access AIM...
