Old 04-19-2008, 09:18 PM   #1 (permalink)
firecracker37's Avatar
firecracker37 is on a distinguished road
Send a message via ICQ to firecracker37 Send a message via MSN to firecracker37 Send a message via Skype™ to firecracker37
Default Q not showing profiles
Recently updated the Q, and now when I go to change profiles the list is completly empty! My home screen shows that I am in the normal profile, but I can't change. Also when I hold down home, that menu doesn't show any profiles either. Was their maybe a file or registry edit that erased them?
Thanks for the help.
firecracker37 is offline
Old 06-28-2008, 10:05 AM   #2 (permalink)
kalina's Avatar
kalina is on a distinguished road
Music or Audio Sounds familiar....
Could someone PM the profile files to me???? PLEASE....all of mine were erased when I did my last master reset and update.
**they are the
*.prof.xml files
Thanks
Every day that I teach, I learn something new. Everything I learn, I use to broaden the minds of those around me.
Teach to learn - Learn to teach
Explore and absorb the knowledge around you!!
kalina is offline
Old 06-28-2008, 06:18 PM   #3 (permalink)
Geekster's Avatar
**they are the
*.prof.xml files
Thanks
http://www.everythingq.com/forum/mot...s-16704-4.html
^^^^OK, now that this problem is in one place. & this is all of the problem? ^^^^^
After you updated your phone (MOL 4 or 6.1?) Need more specifics here, I think but let's take a stab @ this.
After your update did you Master Reset the phone? Do the shut down & key combination that is compatible to your version of the Moto Q & then, again, using System Tools> Master Reset. (Is it in a different place on the Q9c?)
Whatever you did to the phone will be lost so back up what you don't want to loose. Hopefully this will restore everything that is in your ROM on your phone.
Let ppl know if you need more help.
I don't have a solution, but I admire your problem.
It's hard to find a Friend who is:
96% Funky
97% Sexy
98% Loving
99% Talented
And
100% Sweet
So...... Don't lose me, okay??
http://www.frappr.com/?a=constellati...d=137440517530
Geekster is offline
Old 06-28-2008, 07:18 PM   #4 (permalink)
kalina's Avatar
I did the rest because I wanted to return the phone back to factory. Before I did the update from the Motorola site, everything was there. After the update, everything vanished. I don't want to restore the rest of that other stuff to the phone. I just want my profiles back. (Master reset and update done within the past 30 days)
Any ideas...websites....I'm grabbing at staws here....
kalina is offline
Old 06-28-2008, 07:49 PM   #5 (permalink)
Geekster's Avatar
Well, dang honey! I've got nuttin left.
Which version of the Q do you have?
Original Q w/ MOL4? MOL3?
Q9C w/ 6.1 update?
Someone will jump in here but I really don't understand why the MR didn't fix it since it's in ROM. And now wondering if you are going to encounter other problems b/c of a bad ROM?
Good luck and nice to meet you...
96% Funky
97% Sexy
98% Loving
99% Talented
And
100% Sweet
Geekster is offline
Old 06-28-2008, 08:00 PM   #6 (permalink)
kalina's Avatar
Lightbulb Eureka!!!! ...and not the Vacuum...
I found them...they are now listed as *.def.prof.xml - I'm in the process of creating a new folder and telling the registry where to find them (as well as copying them to my external hard drive for future retrieval)
My settings say this: (and I have no idea what any of it means)
Thanks for keeping me thinking, or I would have never come up with it...
Q2-BP_C_06.2C.00R
MP_BSP_C_02.07.61-69P_HW_P2.1
I guess that's different from the old one.
Q9C w/ 6.1 update?
kalina is offline
Old 06-28-2008, 08:03 PM   #7 (permalink)
Geekster's Avatar
Sorry I couldn't be of more help but glad you go it worked out.
Good for you!!
Pat yourself on the back.
96% Funky
97% Sexy
98% Loving
99% Talented
And
100% Sweet
Geekster is offline
