Old 10-05-2007, 10:02 AM   #1 (permalink)
cindy21601 is on a distinguished road
Default Problems Sending Video
I have send a video via MMS from my Motorola Q to another Motorola Q. Both Q's are Verizon wireless carriers. Sent the video, showed being send in MMS sent box and after sending prompted that sending was complete. The Motorola Q recipient said they did not recieve. Can you tell me why they did not receive and were it possibly went? I sent via MMS through their Q cell number not through email.
cindy21601 is offline
Old 10-05-2007, 11:27 AM   #2 (permalink)
I am new to the forum and am wondering if I am doing something incorrect in my posting. I see that I have had veiwer but no response. Am I hitting the correct forum?
Old 10-05-2007, 12:45 PM   #3 (permalink)
you're doing the right thing, and yes many members read/view the thread but do not have a direct solution for your issue so they don't reply...
now i on the other hand reply but am not sure why this has happened to you.. try to have the other person send you a clip, or start by just sending a picture.. try to narrow it down.
cindy21601 (10-05-2007)
Old 10-05-2007, 01:03 PM   #4 (permalink)
Thank you!!
