Old 04-15-2007, 10:43 PM   #1 (permalink)
captain98 is on a distinguished road
Default problems connecting to pc
I was finally able to get the activesync to work with my pc. I downloaded a file on my pc and transfered it over to my mobile phone connection. It's a cab file, so how do I install that onto my phone?
captain98 is offline
Old 04-15-2007, 10:52 PM   #2 (permalink)
Geckotek is on a distinguished road
You might try this:
http://hardware.mcse.ms/archive35-2004-10-94898.html
Geckotek is offline
Old 04-15-2007, 10:53 PM   #3 (permalink)
scubasteve's Avatar
scubasteve is on a distinguished road
Go to file, then delete the device (make sure it isnt connected) then try again. Make sure you are using AS 4.5
scubasteve is offline
