Old 05-01-2007, 11:56 PM   #1 (permalink)
clubromney is on a distinguished road
Default Problem with V2R Photodialer
Ok, so I must be doing something wrong here. I installed the trial version of photodialer to see if I would like it. The installation went fine but after I enable the plugin nothing happens (ie nothing is added to the home screen). I have uninstalled and reinstalled several times and have read through their help manual but there isn't anything for troubleshooting the plugin not showing up after it is enabled. Any ideas?
clubromney is offline
Old 05-02-2007, 08:45 AM   #2 (permalink)
don't you have to select a home screen that uses this plugin.. i am not sure since i never used PhotoDialer (nor am i planning on using it :} but that's my first guess.
Old 05-02-2007, 08:51 AM   #3 (permalink)
shaun0207's Avatar
shaun0207 is on a distinguished road
Send a message via MSN to shaun0207 Send a message via Yahoo to shaun0207
After you install it, scroll up on your home screen and see if it is there. You may have a long home screen like I do and some times, it wont show until you scroll up. Have you entered contacts into it yet?
shaun0207 is offline
Old 05-02-2007, 01:08 PM   #4 (permalink)
so it finally started working. I uninstalled/reinstalled it once again, but this time when I enabled it a message appeared saying that my home screen was copy protected or something and that it had created a new one. now it works just fine. cool plugin...highly recommended
Old 05-02-2007, 01:12 PM   #5 (permalink)
Smile
glad to hear you got it working... i'm fine dialing people's number the old fashioned way :}
(plus a lot of people on my contact list are not pretty enough i would want them on my home screen
