Old 07-13-2007, 09:51 AM   #11 (permalink)
im going to start uninstalling programs (atleast the last few that i have done) to see if i did put it on the SD card...maybe i made an oopsie
anyother thoughts in the mean time would be welcome
Old 07-13-2007, 10:17 AM   #12 (permalink)
Default After the Uninstall
so i did a little house cleaning...got my memory up to 13megs free...still not the 17-20 im used to but soooooo much better than the 3megs that i had....ill deal with that for now...
ill keep looking and see what else i can find...if anything at all its good summer cleaning...LOL
thanks RB and GEPTRONIXDJS for your thoughts
Old 07-13-2007, 11:05 AM   #13 (permalink)
you're welcome buddy.. i have supposedly 15 MB free, but then again which program will/can we believe :}
Old 07-13-2007, 11:13 AM   #14 (permalink)
yea i know...
i even check the standard Q memory manager with that WM5.0 task manager i found and they matched up...so there is something there...ill have to check out my emails that i have saved...maybe something crazy large got tranfered over that i didnt know of...
Old 07-13-2007, 12:03 PM   #15 (permalink)
GEPTRONIXDJS's Avatar
GEPTRONIXDJS is on a distinguished road
quite welcome i am now in the process of removing some stuff to see if it works for me
GEPTRONIX DEEJAYS
FOR ALL YOUR PARTY NEEDS
GEPTRONIXDJS is offline
Old 07-13-2007, 01:06 PM   #16 (permalink)
braeleure2 is on a distinguished road
Default Windows in RAM+ROM; misreported 4GB mini-SD
I suspect File Manager returns total RAM + ROM used to store the Windows directory.
Related side note - File Manager says my mini-SD is 2GB, but Memory Manager correctly says its 4GB.
braeleure2 is offline
Old 07-13-2007, 01:08 PM   #17 (permalink)
applejosh is on a distinguished road
Well, I don't know where all your space went to, but I have an explanation for the memory sizes you're seeing. The Q has 64MB of RAM (real RAM, similar to the RAM in your PC) and 128MB Flash (similar purpose to the hard drive in your system) of which a lot is part of the ROM image (i.e. you can't selectively remove certain apps the phone provider and Microsoft feel are neessary). I believe it's in the flash memory where all your apps get stored if installed to the "device" rather than a storage card.
As far as other places to look, have you looked in the Application Data folder? I know if I use Opera mobile, it sticks loads of files in the Opera\cache4 subdirectory. Also if you horde today screens like I do, the Home subdir fills up pretty quickly. Also, Live Search and Google maps take up lots of space. Beyond that, what are the sizes of your internal databases (I think pim.vol and cemail.vol in the root directory are these)?
applejosh is offline
Old 07-13-2007, 01:14 PM   #18 (permalink)
yea i was thinking that too...but i guess i kinda talked myself out of thinking that was right...but its possible
Old 07-13-2007, 01:16 PM   #19 (permalink)
well i dont use opera....
only have a the screen i use plus the standard screens in the \home folder
pim.vol is 3mb
cemial.vol is 5mb
and all programs are installed on SD card....who knows....
just wierd that it disappeared like that when the week earlier it was much more
thanks for your input!
Old 07-18-2007, 07:20 PM   #20 (permalink)
Default Found It!!!!
ok so i was going through my emails and removing misc. things and i came across my drafts folder which had '1' file in it
i dont remember making a draft so i go and look at it....somehow (im sure i did it but dont remember) there was an email in there i was attempting to send that had a 5meg attachement!!!!
i removed this email and bam...my memory is back up to 20megs free!
anywho...long story short...i found the problem and it was my own doing (as most of the problems that happen are )
thanks for all your help and thoughts....
