Old 07-08-2006, 04:01 PM   #11 (permalink)
Lazyprsn is on a distinguished road
Mainly this line confuses me "For locked Smartphone devices, use tGetFile.dll which is delivered with a compatible program, and has digital signature. "
How is it delivered with a compatible program? Does that just mean I download one of the programs and that's it? Or do I have to do something else?
Lazyprsn is offline
Old 08-09-2006, 02:05 AM   #12 (permalink)
JessJenn's Avatar
JessJenn is on a distinguished road
Originally Posted by Lazyprsn
I'm confused also. Maybe I'm dumb, but could someone do a quick step-by-step?
Follow my instructions here: http://www.everythingq.com/forum/sof....html#post4648
but use the SNES emulator in this thread instead. Disregard the control settings.
JessJenn is offline
Old 09-03-2006, 02:07 AM   #13 (permalink)
dipgolf's Avatar
dipgolf is on a distinguished road
Any good SNES rom sites?
Hotty Toddy.
dipgolf is offline
Old 09-24-2006, 09:52 PM   #14 (permalink)
alongiron is on a distinguished road
The best NES and SNES is at www.vimm.net Check it out!
alongiron is offline
Old 10-08-2006, 12:06 AM   #15 (permalink)
dipgolf's Avatar
SNES games are hard on the q because of the extra buttons compared to the two on NES games. I've basically quit.
Hotty Toddy.
dipgolf is offline
Old 10-08-2006, 07:52 PM   #16 (permalink)
di_nate is on a distinguished road
I'm having some problems. I have the Nes emulator on my q which works prefectly fine. I then made a seperate folder and put the snes emulator in which is a .rar file and not a .exe file. It will not let me open the snes emulator so i can't even try to open a rom. What is the problem?
di_nate is offline
Old 10-08-2006, 08:04 PM   #17 (permalink)
dipgolf's Avatar
.rar is the same as .zip. You need to download WinRAR which is free (google it) and open the .rar file on your computer like a .zip. The .exe is in the .rar file, move that to your Q.
Hotty Toddy.
dipgolf is offline
Old 10-08-2006, 08:26 PM   #18 (permalink)
thanks for the quick response! going to go do that now
di_nate is offline
Old 10-08-2006, 08:36 PM   #19 (permalink)
ok, now the emulator opens. But I cannot load any roms. They do not appear.
di_nate is offline
Old 10-08-2006, 09:52 PM   #20 (permalink)
The roms i'm trying to open are .smc files. I can find them, but once I select them, the loading thing closes and i'm back to the home screen of the snes emulator
di_nate is offline
