Old 07-08-2006, 12:58 AM   #1 (permalink)
gravel is on a distinguished road
Default Pocket SNES emulator now working with sound
Play super nintendo games on your Q. Download the emulator,tgetfill and roms and play all the super nintendo games you like with sound.. Here is the link.
PocketSNES 1.52 - MoDaCo
gravel is offline
The Following 2 Users Say Thank You to gravel For This Useful Post:
coolguy827 (08-15-2008), WeldFire (10-11-2007)
Old 07-08-2006, 01:44 AM   #2 (permalink)
Q estion's Avatar
Q estion is on a distinguished road
Send a message via AIM to Q estion
wont load ROMS on my Q anyway...maybe someone else will have better luck?
Q estion is offline
Old 07-08-2006, 01:49 AM   #3 (permalink)
ive been using it all day on my Q. Did you download the new one on the link there? Did you put tgetfile on your Q also? Did you install it to My Documents on the Q?
gravel is offline
Old 07-08-2006, 01:52 AM   #4 (permalink)
Q estion's Avatar
tgetfile is being used for my NES emulator, the hacked version..yes, i downloaded this version yes..does it have to be in my documents?
Q estion is offline
Old 07-08-2006, 01:56 AM   #5 (permalink)
yeh I read somewhere that it has to be in documents to work... It was very easy to set up. let me know if you still are having problems..
isohunt is a good sight for games
gravel is offline
Old 07-08-2006, 02:00 AM   #6 (permalink)
Q estion's Avatar
well...check it out i just got it to acctually try to load, the tgetfile.dll is a little different than the one i am using...it wont load the ROM it locks my phone up..trying to load donkey kong...any ideas?
Q estion is offline
Old 07-08-2006, 02:01 AM   #7 (permalink)
Q estion's Avatar
ok fixed the tgetfile problem i was having...no longer an issue, the rom tries to load now and locks my phone up...any ideas?
Q estion is offline
Old 07-08-2006, 02:29 AM   #8 (permalink)
this one works differently than the nes one, you actually open the rom with the emulater.
gravel is offline
Old 07-08-2006, 02:08 PM   #9 (permalink)
Franco Q is on a distinguished road
Default Can any one expand on how toload the SNES emulator and all additional software onto q
Cuz I am not able to figure it out on my own.
Franco Q is offline
Old 07-08-2006, 02:58 PM   #10 (permalink)
Lazyprsn is on a distinguished road
I'm confused also. Maybe I'm dumb, but could someone do a quick step-by-step?
Lazyprsn is offline
