Old 10-23-2007, 04:15 PM   #1 (permalink)
Stingray is on a distinguished road
Default Non Motorola wall chargers
I have a spare (USB) wall charger for HTC Apache - Sprint 6700. Can that charger be used to charge the Q? Or do we need to stick to OEM wall chargers? What are the drawbacks of Non OEM chargers?
Stingray is offline
Old 10-23-2007, 04:42 PM   #2 (permalink)
bann3d's Avatar
bann3d is on a distinguished road
Don't know the answer to yours, but I have a Blackberry 8703e from work and I was given a wall and car charger for it too. I use it all the time to charge my Q and vice versa with the Q charger for the BB. Hope this helps.
bann3d is offline
Old 10-23-2007, 04:58 PM   #3 (permalink)
i am pretty sure you can use it... why not read the output and compare with the original Q charger.
Old 10-24-2007, 10:29 AM   #4 (permalink)
piranah's Avatar
I use my old razr chargers for my Q, it takes a little longer to charge as the output is different, but they work.
unless the battery is totally dead, then the only thing that I have found that works is the OEM charger. Found that out the hard way when my phone died and went to charge it using the razr charger, go the white screen of death and no charge. i did a master reset not without thinking of changing chargers
When you think you have had a bad day, just remember, somewhere in the world is the worlds' worst doctor, and somebody has an appointment with them tomorrow.
piranah is online now
Old 10-24-2007, 01:08 PM   #5 (permalink)
0100010 is on a distinguished road
I have found that the Q will only accept chargers that provide a power level between 5V/250ma and 5V/800ma.
Insert signature here.
0100010 is offline
Old 10-24-2007, 01:50 PM   #6 (permalink)
muscles007 is on a distinguished road
how is it that the battery can totally die? last night i tried charging my phone to a motorola wall charger, this morning after all that only 1 bar. connected it at work for 2 hours or so, still only 1 power bar. perhaps this is whats wrong with mine, the battry is dying, i don't know but i'm passing a sprint store on my way back to the office (walkng & typing on 42nd st in nyc right now) & i'm going to find out.
muscles007 is offline
Old 10-24-2007, 02:05 PM   #7 (permalink)
Eugene is on a distinguished road
I would think they wouldn't charge on non motorola chargers. Mine won't charge off a non motorola USB cable so there must be something different about the Moto ones.
Eugene is offline
Old 10-26-2007, 03:03 PM   #8 (permalink)
piranah's Avatar
Im talking about when your battery is so low that you cant turn your phone on, etc.
