Old 03-10-2008, 11:51 PM   #1 (permalink)
dowens86 is on a distinguished road
Default No Ringer on Wall charger!! GRRRR
When I plug my Q into the wall, the profile automatically changes to Car and it will not ring!
I change the profile to normal and it will still not work. I restart and plug it into my USB and it will ring while attached to the USB.
But on a wall charge or car charge, it will not work! This is a 2 day old phone from Sprint!
Please help!!
dowens86 is offline
Old 03-10-2008, 11:55 PM   #2 (permalink)
Also, sometimes when I take it off the charger, the phone will lock and I have to take out the battery to restart. Any ideas??
dowens86 is offline
Old 03-11-2008, 12:23 AM   #3 (permalink)
jknight4200's Avatar
jknight4200 is on a distinguished road
Send a message via AIM to jknight4200 Send a message via Yahoo to jknight4200
Check each individual profile setting...and make sure it's not set to switch profiles automatically.
Since it's still new, if all else fails you can always do a master reset! It usually will solve any problems but it wipes the phone clean.
J.K.
~ My Q Apps ~ Homescreens ~
jknight4200 is offline
Old 03-11-2008, 11:14 PM   #4 (permalink)
I'm not sure how to check if it changes to automatically. It's not on automatic! Any ideas guys?
dowens86 is offline
Old 03-11-2008, 11:42 PM   #5 (permalink)
piranah's Avatar
like j said, master reset, it will wipe everything, but it usually solves all problems
Be nice to the nerds, chances are you already work for one..
if ive helped you, help me stay out of jail and donate ...
piranah is offline
Old 03-12-2008, 07:49 PM   #6 (permalink)
The phone is 5 DAYS old.... I've had more bad luck with these things!
dowens86 is offline
